- Wed Nov 21, 2012 10:35 pm
#320560
THANKS EVERYONE WHO HELPED ME ACCOMPLISH THIS SWAP!!
(CIVIC-EG FORUM PEOPLE)
Engine info:
-2001 h22 type s (60 000km) 220hp at 7200 and 163 torque at 6500
The motor is running with an Obd1 ECU. the timing belt change, water pump change, water pump belt change, valve cover gasket and the timing belt tighner changed to all from HONDA inc.
Parts in the engine bay (might forget some!!!!):
-the timing belt change
-water pump change
- water pump belt change
- valve cover gasket
- timing belt tighner
-Yonaka h22 motor mount for 96-98 civic
-Yonaka H22 Shaft for civic 96-98 civic
-red radiator hose kit f
-Supertech valve,Spring valves,Reatainers and seals
-radiator
-yoshimoto fan+shroud
- COld air intake and filter
-VMH fuel filter
- B&M fuel pressur gauge
-Accord euro R shift link
Body parts: (might forget some here tooo!!!!)
-98 integra rear disk brake convertion
- 4 new disk brakes and pads
- polyurethane bushing for the rear arm
-Lower control arm (polyurethan bushing)
-rear camber kit
-rear lower tension bar
-4 new shocks tokiko
-skunk2 drop kit sping
-front blackwork camber kit
-2 new rear bearing and hub assembly
- 2 1/4 exaust systeme (stainlesteel)
-Catback exaust reactive
- panasonic deck and 4 speakers
- SI cluster
-16 inch mag
- Tire 205/45R16
-new batterie
Engine info:
-water pump change
-radiator
-VMH fuel filter
-rear camber kit
- SI cluster
-16 inch mag
- Tire 205/45R16
-new batterie
H old
O n
N ot
D one
A ccelerating
O n
N ot
D one
A ccelerating
