- Sun Jan 06, 2013 9:13 am
#323406
Got a alot done in the three days i had home before i leave again. started wet sanding the car and removing the lights and sidemirrors etc
tail lights gone. was a pain in the A$$ when you have big hands trying to get the four bolts out the back of the brake lights
Of course i found some more spots to touch up on the car and went through and touched up some spots with the 320 grit wet sand. Word to the wise make sure you use enough harder in the filler or it will just had a few hours to you project sanding it all off. me-1 filler 1
So accepting defeat started painting rear bumer. few cosmetic probs but hardly noticeable
first coat ofter sanding
2nd coat and left to dry over night
wet sanded with 1200 and applied 2 and half more coats since wasnt much left in the can. just need to clear coat when i get back
all the pieces if finished minus clear coat on rear bumper
need to re tape the car off and should be ready for paint when get back. had to buy outthe local home depot of gloss almond. was runnning out and if you ever lived on a island you will learn to buy it when u see it or it wont be there when you need it.
