By dbq_93t
#271152 I took a car on trade and I am afraid I don't know much about exactly what I have here. I was hoping someone more Honda educated could enlighten me as to what exactly I have gotten myself into. The engine code reads d16z6.
photos should be able to be seen here:
http://myp.mypicturetown.com/myphoto/member/myphoto.jsp
By B20vtec-turbo
#271153 The link to your photo's is asking for a email address and password. Upload your photo's to photobucket.com and put them on here using the IMG tab.
You have the d series vtec engine, I don't know much about SOHC engines, I'm a B series guy...
By blk92hb
#271155 here you go.
D16Z6VTEC
Found in
1992–1995 Honda Civic Si
1992–1995 Honda Civic EX, EX-V
1992–1995 Honda Civic ESi (European Market)
1993–1995 Honda Del Sol Si (US)
1993–1995 Honda Del Sol ESi (European)
Displacement : 1,590 cc (97 cu in)
Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
Rod Length : 137 mm
Rod Ratio : 1.52~
Compression : 9.2:1
Power : 125 bhp (93.2 kW, 127 PS) at 6,600 rpm
Torque : 106 ft·lb (14.7 kg/m, 144 Nm) at 5,200 rpm
Volumetric Efficiency : 87.68%
Redline : 7,200 rpm
Fuel Cut : 7,411 rpm
VTEC Switchover : 4,800 rpm
Fuel Control : OBD-1 MPFI
Head Code : P08
ECU Code : P28
the z6 is a good motor, with a little bolt ons you can have a very peppy dd.
