- Thu Dec 29, 2011 2:49 pm
#287496
update!!! energy suspension urethane bushings being installed
[img][img]http://i1089.photobucket.com/albums/i360/_roy1979/Snapbucket/8B1D186D-orig.jpg[/img]
very annoying process
[/img]
[img][img]http://i1089.photobucket.com/albums/i360/_roy1979/Snapbucket/C543E45E-orig.jpg[/img][/img]
- Tue Jan 17, 2012 1:55 am
#290379
ok finally got those put in!!!!!! it really wasnt that bad. only reason it took so long was i had changed the rear control arms to integras (so i can run a rear sway bar) and they have larger diameter. would have been nice to know. other than that the job was easy. took a total of about 4 hours actual work time. also while i was in there installed some russell SS braided brake lines and changed all the brake fluid to synthetic. now at the body shop to fix the crunch in the front. pics to follow. also gettingh new rubber for my fat fives
- Tue Jan 17, 2012 6:05 pm
#290513
Nice!
roy93 wrote:ok finally got those put in!!!!!! it really wasnt that bad. only reason it took so long was i had changed the rear control arms to integras (so i can run a rear sway bar) and they have larger diameter. would have been nice to know. other than that the job was easy. took a total of about 4 hours actual work time. also while i was in there installed some russell SS braided brake lines and changed all the brake fluid to synthetic. now at the body shop to fix the crunch in the front. pics to follow. also gettingh new rubber for my fat fives
Nice!
- Wed Jan 25, 2012 6:24 am
#291908
nice progress...nice find with the 4DR
EG8 Build: http://civic-eg.com/viewtopic.php?t=20985&highlight=
EK Build: http://civic-eg.com/viewtopic.php?t=257 ... highlight= SOLD
#10 of The Civic-EG.com Ferio Squad
- Mon Jan 30, 2012 11:00 pm
#292646
nice come up bro deals like that don't come around everyday and good work on the bushings those are a pita and i only did the rear and front lower control arms cant wait for the rest
http://civic-eg.com/viewtopic.php?t=17296
My for sale thread check it out!
http://www.civic-eg.com/viewtopic.php?t=25828
#3 CivicEG.com Ferio Squad
- Fri Feb 03, 2012 12:54 am
#293097
got new pics to post first my titanium strut bars
[img][img]http://i1089.photobucket.com/albums/i360/_roy1979/Snapbucket/43762A04-orig.jpg[/img]
[/img]
now the bumper got fixed
[img][img]http://i1089.photobucket.com/albums/i360/_roy1979/Snapbucket/484DAC63-orig.jpg[/img]
and energy suspension install
[/img]
[img][img]http://i1089.photobucket.com/albums/i360/_roy1979/Snapbucket/8C471327-orig.jpg[/img][/img]
[/img]
[/img]
- Wed Feb 15, 2012 1:54 am
#294964
new pics!!! motor is bolted in but not running yet. got a new to me rad. too. I'm sure there will be bugs but that's to be expected. got integra front calipers and rotors. planning on doing password drilled and slotted for front and rear.
[img][img]http://i1089.photobucket.com/albums/i360/_roy1979/Snapbucket/CAD81713-orig.jpg[/img]
[/img]
the difference between stock and integra front rotors
[/img][IMG]http://i1089.photobucket.com/albums/i360/_roy1979/Snapbucket/6F1161D6-orig.jpg
[img][img]http://i1089.photobucket.com/albums/i360/_roy1979/Snapbucket/D34E57CE-orig.jpg[/img]
also got nrg upper strut braces
[/img]
[/img]
[/img]
- Sun Mar 04, 2012 2:31 pm
#296961
finally got motor in and going. just have to wire in the vtec stuff and done. although i have the mated p30 ecu my harness doesn't come stock with a knock sensor or vtec wiring so gotta do that stuff the hard way. i think i've about got it but its very confusing. im considering doing a hondata system as well i hear they are bad ass when you start adding goodies
- Mon Mar 05, 2012 5:16 am
#297048
got the vtec wired up and kicking hard. now just have to smooth things out. at idle it revs up and down from 1k-2.5k really annoying. but i think its a bad sensor or maybe even a vacume hose off. it also wants to studder a little at low rpms. friend of mine says its the 310cc injectors and not enough fire. cause it runs great at higher rpms. pics will follow soon
- Sun Sep 09, 2012 11:27 pm
#315330
got the idle fixed was only a throttle body gasket problem. have a throttle sticking issue now though lol but its not too bad. getting the stock fr and r bumpers repainted to put back on. since doing my wifes build up i like the way it looks better with the oem stuff.
- Page 3 of 4
- 1
- 2
- 3
- 4
