By FG2_Andrew
#350431 will bolt directly in...... except for one bolt in the inner rear. it's up to you if that feels safe to you or not.
you want DC2 rails
By danmain-eg
#350434 thanks for the quick reply man :) looks like i will be getting a set of these then!
By TrailerTrash
#350439 if i remember correctly, you can use a dremel and make the bolt hole(in the rail itself) that doesnt line up into more of a slot shape and youll be able to bolt it down
