By Trix
#330018 ok guys ever since i replaced the ballast on my HID bulbs i lose signal in certain places when im driving, I know it has to do with the headlights, bc when i turn them off the signal comes back then i lose it again when i turn them on...
Is there anyway to fix this problem?
By Leppy
#330021 Check grounds?
By Trix
#330023 to what? i dont have anything going to my battery unless you are talking about the ground that connects to the stock headlight connector?
By Leppy
#330024
Trix wrote:to what? i dont have anything going to my battery unless you are talking about the ground that connects to the stock headlight connector?
I don't know how they are set up, but if there are grounds at the headlights or ballasts, check those. I'm no expert, but that's where I'd start.
By Trix
#330025 ok that i can do, idk if it makes a difference but i went from DC to AC ballasts
