By EGCiviCKid
#286367 hi just wondering if anyone knows of a detailed step by step guide on removing and installing a dials,
ive just bought a kit of ebay and it came with a pathetic instruction book including the use of spoons to remove dash.
any info would be appreciated cheers
By CivicJaz
#286371 Does it look like this?
By CivicJaz
#286397 Aye i fitted mine ok by instructions, used the two teaspoon method to pop needles off, but take the little plastic stopper out by hand carefully and let the rev and mileage needles drop, remember exactly where they sit as youll have to put them back on the exact way after putting white face on and before that little black needle stopper.
As for fuel and temp gauge, id advise you slice white dial in half and slide UNDER needles, as i knacked mine up and had to get another stock dial.
Also youll need to cut a rectangle out under fuel/temp needles for your handbreak and engine/ignition light.
When all done and dusted you might also want to cut white faces in a circle shape like stock to make sure bulbs illuminate all faces.
Read up on my build up just incase that helps
By EGCiviCKid
#286401 thanks alot will give it ago when i get home! :P
