- Wed Nov 23, 2011 6:19 pm
#282699
i bought a shell. it was an auto. put a b16a2 into it. i got a new cluster to replace the auto one. it is currently half in because a plug is different. i thought it was all plug and play? any help is appreciated. do i have to get a new harness or anything?
- Wed Nov 23, 2011 6:35 pm
#282702
What kind of cluster did you buy? Stock EG6 cluster?
When you swapped in the B16a2 into your eg, did you end up swapping the whole wiring harness? If so, there is a chance you need an EK cluster because the B16a2 is originally out of the USDM Civic SIR
Eg circuit:
http://lh6.ggpht.com/_dKrAeypy4kc/S1VLD ... GP5440.JPG
Ek circuit:
http://carphotos.cardomain.com/ride_ima ... _large.jpg
One of the connectors may be simular in size but if your whole harness is swapped you will probably need a new cluster out of an EK (96-00) civic
