By mitch6
#282793 I dont know if this is what u already have as the converted plugs you mentioned, but did you have the harness that converts OBD1 to OBD2?
I saw it off this fourm: http://www.hondacivicforum.com/forum/eg ... obd1-8409/
This might be somethig that you need unless you had it: http://hasport.com/store/index.php/acce ... 1-2aj.html
This thread tells you the difference between OBD2A and the OBD2B harness conversion: http://www.d-series.org/forums/general- ... rness.html
Because I am not too sure which one you need... or if you need them at all....
From all the threads I have been reading P30 ECU is the best!
here is some additional info: http://honda-tech.com/showthread.php?t=2944403
Once again people of civic-eg.com support or ideas would be appreciated :thumb:
By grrttwright
#282818 yeah, all of the harnesses are bod1 so shouldnt have to change anything. thanks for looking though.
