By ghskid06
#222871 im pretty sure there should def be a screw. maybe there is a plastic cover you have to pop off first.
By Bblackyy
#222872 im trying to pop off the front but it seems like its not coming off , dont wanan break anything.
By ghskid06
#222950 does it mount to the roof or to the window?
You should be able to get any covers off with a small flathead screwdriver.
By ImThaBean
#223263 If its mounted to the glass its held on by a prong. If you look on the very top/bottom, there should be a little hole to stick a small flat screw driver or anything flat the size of the hole. Ram it in there and pull. should be from the bottom, stick the screw driver/flat metal thing in there and pull the mirror up while doing it. Depending on how long its been on there wiggle it as you pull up.
