- Thu Feb 25, 2010 8:20 pm
#177781
depends really its actually quite a simple task as long as no one previously fucked with it.....
quick over veiw...
12mm bolt and nut i think holding the shifter arm to the shifter (this arm you dont need to remove fully just unhook from shifter this is the arm of the so called bitch pin)
i think its eitehr 2 12mm's or 2 14mm's near the shifter itself going from the bottom thru a metal peice and bushing into the car....
and a 12mm to unhook the stabalizer bar and then you can remove that assembly so its easier to work on outside the car.....
Since unless its been altered it will need 2 10mm bolts removed from 2 bolts holding it in there....you may need vice grips or plyers to hold it once you get it loose enough....and then you can remove the retaining plate and pop out the shifter
(I would highly recommend switching out your bushings for energy suspension polyurethane ones since you have it all apart anyhow just pop the stok bushings off and replace with new easy simple and 100x's better than stock....)
hope this helps its so very simple and upon reinserting the shifter be careful to get it thru the boot since you could pop a hole thru it you can remove your center console to make this easier but to be honest you really dont need to....
1980 volvo 242
2001 crv
