Will these looms work together
Wed Feb 01, 2012 5:32 pm
by CJJONES
Done a engine swap d13b2 to d16z6 using the d13 rear loom and fuse box and the d16 dash and engine loom everything has plugged in so far will this work if I just run power to the pump ? Thanks CJ
Wed Feb 01, 2012 7:30 pm
by stubrun
Providing you have the 3 plugs on the passenger side strut tower and obd1 ecu plugs it should be fine. Remember you will need to upgrade the fuel tank or pump.
Wed Feb 01, 2012 8:28 pm
by CJJONES
stubrun wrote:Providing you have the 3 plugs on the passenger side strut tower and obd1 ecu plugs it should be fine. Remember you will need to upgrade the fuel tank or pump.
Yeah I got a tank have to look at the 3 plugs at the strut top but i think theres 3 there the ecu is plugged in thanks for your reply CJ
