- Thu Aug 14, 2008 5:42 pm
#65968
Tried searching but no luck.
PROBLEM:
Ok so my gearbox is working perfectly.
However the gear stick is floppy even if a gear is engaged it will flop around in a horizontal manner.
I know there is a spring which I believe is in the gearbox itself which returns the gear stick in to it's original place when placed into neutral.
QUESTION:
How hard is it to replace this spring so the gear stick will return to its eutral state properly?
I have a B-series engine btw with a box which has an LSD.
Thanks
PROBLEM:
QUESTION:
Thanks
