By myers503
#345618 lmost done with my LS swap parts list,
I need tranny bolts. I've been searching parts places OEM and alike and ebay has been the only place I can find tranny bolts. I would like to order from honda, but I cannot locate a part number anywhere.
So I have a 96 ls trans and a 96 ls b18b1. I need the bolts to mate the two together. Can anyone help me out?
Thanks in advance :thumb:
By myers503
#345619 Image
in RED
By TrailerTrash
#345626 http://www.acuraoemparts.com/delray/jsp ... vinsrch=no
thats as close as i could find but it doesnt have the bolts listed :?
By myers503
#345627 same here. Thats the site I got my t bracket part numbers from though lol.
I imagine the si em, and the del sol SI using the b16 would use the same bolts? so maybe the honda guy can look it up that way.. hmm. ill try them tomorrow.
By myers503
#345692 and BOOM:
They are listed under
Engine Wire Harness - CLAMP
90050-PG7-000 BOLT, FLANGE (12X65) qty 2
90051-PE0-000 BOLT, FLANGE (12X70) qty 3
http://www.acuraautomotiveparts.org...omp=List All&vinnoT=&trim=&trans=&view=normal
#21 and 22
By HeikDiesel
#345732 Just a heads up what you highlighted in red are not the trans to engine bolts. Those bolts hold the two halves of the trans together. But yes you did find the correct part numbers if you are looking for the trans to engine bolts.
