- Sat Sep 13, 2008 12:01 am
#69503
Gotta love the Full Race guys, they're the shit. now i need to find one that tells how to disassemble and reassemble the mainshaft and countershaft
- Tue Mar 15, 2011 12:53 am
#243930
hi i have come into a bit of trouble with the snap ring. i was resealing the case. it sat down nice and smooth with a tiny gap and when i was tightening the bolts i heard a crunch so i took a look in side and the snap ring is all bent. just wondering how important is the snap ring or is it worth replacing. dont want any troubles in the future
- Tue Mar 15, 2011 4:24 am
#243974
The snap ring must be installed properly to maintain the correct alignment of the counter shaft to the main shaft.
I have had to pull the snap ring out and straighten it out using a hammer and a block of wood. When you put it back together be sure the ring is in the groove in the bearing.
- Tue Mar 15, 2011 12:30 pm
#244010
sweet cheers mate i will pull it apart later and see what i can do
Datsmart wrote:The snap ring must be installed properly to maintain the correct alignment of the counter shaft to the main shaft.
- Sun May 08, 2011 1:26 am
#254202
The 2.0 never happened. I rebuilt the second transmission but forgot to take pics doing so.
2017 Chevy BoltEV DD |2001 Honda CRV SE
- Thu Jul 21, 2011 4:16 am
#264312
i have a bearing going out in my trans, just not sure which one it is. when sitting in neutral it growls if i hold the clutch pedal in the noise stops. i had the same noise in my other trans so i bought this 1 for $50 off cl and it was fine for 6 months now it makes the same noise as the old 1. i think it is the main shaft bearing, i was gonna fix my old trans and swap it back in cause i found out monday that i have oil leaking from my trans.. seams to be leaking from the center of the two halves.
