- Thu Jul 25, 2013 12:25 am
#334681
i just dropped in a b20b in my coupe with a b16 si transmission it does not have 3rd gear nor will it let u down shift back to 2nd from 4th gear and 2nd gear speed until i come to complete stop what do u suggest i do buy all new 3rd gear set up or buy a full rebuild kit all other gears work perfect
- Thu Jul 25, 2013 1:17 am
#334684
Sounds like a syncro.
- Thu Jul 25, 2013 9:33 pm
#334714
should i just buy syncro rebuild set and 3rd gear just to be safe?
- Fri Jul 26, 2013 8:40 pm
#334748
You're more than likely going to have to replace the hub and 3rd gear. If it's so bad it won't go into gear I'm sure those are trashed as well.
1992 Honda Civic SIR-S
- Mon Jul 29, 2013 12:22 am
#334828
alright cool ill look more into it as this my only car i can only have it down for a couple of days ill just order everything i need and replace it all even if its not bad were do you guys suggest i order my rebuild kit and gears?
