By EJ civic Juan
#334681 i just dropped in a b20b in my coupe with a b16 si transmission it does not have 3rd gear nor will it let u down shift back to 2nd from 4th gear and 2nd gear speed until i come to complete stop what do u suggest i do buy all new 3rd gear set up or buy a full rebuild kit all other gears work perfect :x
By nd1983
#334684 Sounds like a syncro.
By EJ civic Juan
#334714 should i just buy syncro rebuild set and 3rd gear just to be safe?
By nd1983
#334746 if you are willing to open it up. wait until its open then replace what needs to be. i'm just saying from experience but it could be more, less or something else.
By HeikDiesel
#334748 You're more than likely going to have to replace the hub and 3rd gear. If it's so bad it won't go into gear I'm sure those are trashed as well.
By EJ civic Juan
#334828 alright cool ill look more into it as this my only car i can only have it down for a couple of days ill just order everything i need and replace it all even if its not bad were do you guys suggest i order my rebuild kit and gears?
