#331288 no..
auto have flex plates that the converter bolts to
mannys have a flywheel.. two diff things
By wolfman93
#331289 :x damn it. Ok thanks
#331290 stock d serise flex plate-auto
d series flywheel, also tells you the diff between efs
By wolfman93
#331315 Auto harness work on manual?
#331323 should you will have some extra connectors for the shift solenoids for the transmission, but for the most part everything is the same
By wolfman93
#331330 Ok thanks man
