- Fri Apr 27, 2012 11:09 pm
#303142
So you guys are going to be shock when you read this. I called my friend Jake who is a Honda tech. I told him about my issue with the tranny not draining and Not taking any fluid(it spills like it was full) Well technically it was, even though I properly took out the drain plug and filling bolt.
Jake asked me if I had replaced the tranny or recently had it rebuilt. After telling him the history of this car he then asked me to get a small screw driver and see how far into the tranny it will go. WTF I thought, but to my surprise there were plastic caps pushed in all the way in both plugs.
Have any of you guys seeing this before? I use to change the fluid in my 94 every 3 or 4 oil changes and never experience this before.
Jake asked me for the serial number of the transmission and my vin#. 2 hrs later he called me back and told me that the trans in my car is not the factory installed one. He also thinks that this one has been rebuild by honda dealer or a shop that does work for a dealer, because in his place of work thats how the receive their trannys back for the shop. The installer forgot to remove the plastic plugs!!!
95 EX returning to life!!!
