- Wed Feb 08, 2012 7:46 am
#293866
If you want to build a custom gear box, the 97-01 CR-V Has a 4.562 final drive.
If your not afraid of opening up a Transmission, the least expensive way to make a "Go Fast" transmission would be getting a 94-01 Integra LS Transmission and a 97-01 CR-V Tranmission. All of the CR-V gears are shorter then the Integra LS gears as they have to move a 3000lb suv, shorter gears make that happen easier.
As you can not just bolt a CR-V Tranny in with out a Custom mount and swapped to cable linkage, If you take the CR-V 1-5 Gears and final drive and put them in a LS Transmission you would have a beast tranny. The effect of this would give you shorter gearing then a B16 Transmission due to the better final drive. Even better if you have a 99-00 EM1 tranny which has a 4.2 final drive. The only transmission with a shorter ratio is the ITR.
The beuty of this setup is it can be done very cheap if you source junkyard tranny's. the 5speed CR-V Trannys are hard to find, but source one and you can have a shorter then b16 tranny for the cheap. If you wanted to you could even keep the LS 5th gear for better freeway cruising.
97-01 CR-V 5speed ratios:
1st 3.5
2nd 1.956
3rd 1.344
4th 1.071
5th .812
final 4.562
delsol VTEC Ratios:
1st 3.23
2nd 1.105
3rd 1.458
4th 1.107
5th .848
Final 4.4
Plug the ratios into the Transmission calculator and see for your self:
http://www.zealautowerks.com/transcalc.php
