- Wed Jan 05, 2011 11:44 pm
#231646
Well i bought a automatic 6 gen civic an i was wondering if my shift linkage, tranny mount, axles will work. And also if i do have to mess with wiring when i do? Thanks for any help.
- Fri Jan 07, 2011 12:16 am
#231825
Bump
- Fri Jan 07, 2011 4:12 am
#231850
what shift linkage, tranny mount, axles do you have? From an EG? The mount is different, I'm 99% sure the shift linkage should be the same (unless its from a del sol), and the axles are the same. you can even reuse the auto tranny axles because all the d series manual and auto axles are the same.
For wiring, just wire up your reverse lights and clutch switch - all the same as a 92-95 manual swap
My 1992 SOHC Turbo Hatch
- Fri Jan 07, 2011 5:39 am
#231861
Shift Linkage are different, the EG/DC Ones will be longer. Delsols way to long. Ek Linkage is about 2 inches shorter. You can put Eg Linkage into a Ek and drive it however 4th gear is where 3rd would be and 3rd is almost touching the center console.
You will need EK Shiftlinkage, Mounts(passenger and rear "T")The rest of your stuff on the Ek you should be able to reuse.
2017 Chevy BoltEV DD |2001 Honda CRV SE
