- Sun May 03, 2009 8:02 pm
#114686
Hi
Planning on building a competition engine to run in a 1400cc class, Its going to be a low budget, I would be gratful for your advice on it and the best parts to use
The plan is to use a D14 Block with a SOHC vtech head bolted on to it.
Individual throttle bodies, was looking at GSXR 1000 throttle bodies
Fully mappable ecu.
Competition Cam
Y21 Gearbox with a close ratio gearkit and LSD (Will this bolt on to a D14 Block)
I am going to use an ESI 3dr Hatch as a shell as it will simplify wiring.
How much power do you think I would get out of this build.
Fully mappable ecu.
Competition Cam
