N/A build discussion
By robster
#92482 Last week I had my z1 head in the Computertomograph to see how the ports are shaped and if there are some cracks. The head is in perfect condition! So i can start my build! :D
Here you can see the slight difference between the swirl (lower in port) and the non swirl port (upper in port)
I'd like to know where can i take some material off to get better flow? bowl etc.
Intake
Outtake
Image[/img]
By hondajunkee
#92484 Very cool :thumb:
What kind of build are you doing?
By robster
#92610 Block: D16z6
Crank: D16z6
Piston: D16z6
Rod: D16z6
Gasket: D16z6/D15z1 (same)
Head: D15z1 (ported)
Cam:D15z1
IM: D16z6 (modified for EGR)
TB: D16z6
Filter: ITR Box or Walepenis :lol:
ECU: modified D15z1 P07 rev limit 7500 or Hondata S300
Fuel: 98 ROZ
Lambda: 5-Wire
Header: D16z6 or some Custom made
Kat: 100cpsi
Midpipe: 50mm
Muffler: 60mm TwinLoop
Gearbox: VX
Compresion: 11,1:1 :D
