- Wed Sep 24, 2008 10:11 pm
#71373
I have a 1993 Honda Del Sol S (d15b) automatic.
I need the following specs:
Battery Cold Crank Amps
Cooling System capacitie without ac
The Following Belt Tension Specs:
Alternator
Power Steering pump
A /C Compressor
The Following Pistons,Crankshaft, and Bearing Specs:
Crankshaft main journal diameter
main bearing oil clearance
crankshaft rod journal diameter
rod bearing oil clearance
piston clearance
piston ring end gap (compression ring)
Valve Specs:
Valve Stem dia for Intake and exhaust
Valve seat angles for intake and exhaust
Idle Speed
Curb Idle
Fast Idle
Point Gap
Dwell
Ignition TIming
Degrees
TDC at what rpm
Picture of timing marks
Spark plug torque in ft-lbs
Spark plug cable resistance (max) ohms per foot
Ignition timing degree at BTDC
Alternator
Power Steering pump
A /C Compressor
piston clearance
Valve Specs:
Idle Speed
Curb Idle
Fast Idle
Point Gap
Dwell
Ignition TIming
Degrees
TDC at what rpm
1992 Acura Integra- Keeping It Clean
