N/A build discussion
By foxgearshift
#346432 I heard it is possible to just swap an f22a crank and connecting rod with stock jdm pistons, that suppose to bump the comprassion to 11.5:1 or something and still staying stock any one here ever tryed this? Or any one have any info about it?
By tom023
#346439 Bump! I'm guessing something similar would work with the h23 I've got in the garage.
By foxgearshift
#346440 H23 and h22 share the same block however the pistons on the h23 are shorter and the crank is 95mm on the h23 so i think it will work with you if u just replace the pistons, but u wont be able to rev as high as the h22
