- Fri Nov 30, 2012 6:06 am
#321220
I'm not even sure if ima put it my car
rtegra92 wrote:ill put in 2 cents, in response to original question, If you have a engine that can suck some airflow, the v stack could help,
what i have done in the past is tap into my map sensor, at wot through the power band i look for less than .5 in of vacuum.
if you are already at this or better, a v stack wont really help because the air stream is already unrestricted at that engines airflow needs at high load
if you are over .5 in vacuum and want to improve you could experiment with a v stack , BUT the restriction might not actually be the filter but throttle body or ducting
