N/A build discussion
By xNETZx
#230907 Hello guys planing on changing my cams
my question is can i run (lift 11.9mm / duration 264). Exhaust (lift 11mm / duration 259)
on a oem itr valvetrain
this cams have less duration but slightly bigger lift
thanks in advance
By 93hatcheg
#230908 you should be fine i don't see why it wouldn't work. i see people run stage 1 cams on stock gsr valvetrains no prob. and type r valve train is supposed to be a bit better.
but i would get a dyno tune after to get the maximum benifit from them, hope it helps :thumb:
ohh and blox makes good shit man youll be happy :hehe:
By xNETZx
#230911 Thanks man
that is the reply i was looking for
And a remap is a must :thumb: will post dyno sheet after
Thank you for the cooperation dude :thumb:
By 93hatcheg
#230919 hey no prob dude always willing to help a fellow honda enthusiast :thumb: and cant wait to see what those cams bring you power wise :hehe:
By Golden_TypeR
#233914
xNETZx wrote:Thanks man
Ill be checking in to see what numbers you make, I have a stock JDM ITR swap and want to change cams too
