- Wed Sep 15, 2010 11:54 pm
#213892
A buddy of mine wanted me to write out an all motor build. Let me know what you think of it.
-B20b sleeved-85mm Bore, Hone, Decked, Micropolish and Balance Crank
-Carrol Rods
-CP 15:1 custom pistons w/ rings
-ACL Bearings
-OEM 3 Layer 85mm Head Gasket
-Portflow port & polish, Super Tech Stainless Steel nitride coated valves, dual valve springs, titanium retainers, competition 3 angle valve job
-ARP head studs and rod bolts
-Mishimoto Full Length Radiator w/ Slim Fan
-TWM Individual Throttle Bodies-52mm
-Apexi Racing Spark Plugs
-MSD Ignition Custom Spark Plug Wire Set- 8.5mm
-Crane Multi-Spark Ignition Kit
-MSD Distributor cap & Rotor
-High End Tri-Y Headers
-P28 ECU w/ Hondata S200
-Walbro 255 LPH Fuel Pump
-Lenzo Drag Slicks
-Level 2.9 axels
-Skunk 2 Pro-Series Ground Control Coilovers
-Hasport Motor Mounts
-Type-R Tranny
-ACT Stage 3 Clutch kit
-Findaza Flywheel- 8lbs.
-Greddy Timing Belt
-CTR Crank Pulley
-Crower Stage 4 cams
-NRG Tech Traction Control Bars
-Skunk 2 Short throw shifter
Alright well that's what I got so far. Please by all means add onto it if there is anything im missing (which im sure there is a lot) or if I should get a different company part over one I have listed. Thanks.
-Carrol Rods
-ACL Bearings
-Lenzo Drag Slicks
-Level 2.9 axels
-Type-R Tranny
-Greddy Timing Belt
-CTR Crank Pulley
