N/A build discussion
By berg89
#203195 Im doing n/a with my d series, an i was wondering if my stock rods could handle it? My buddy says they can but i wanna be safe.
By d-mon
#203231 stock d16 rods can handle more power than a N/A d-sereies is capable of.
d15 rods are thinner but still strong enough (and lighter).
By Classiccarsrule85
#203237
d-mon wrote:stock d16 rods can handle more power than a N/A d-sereies is capable of.
x2 but if you want to be safe just grab some slightly used ls rods and put them in cheaper solution but yea the stock d sereis rods will handle thepower youd be making with the n/a
By berg89
#203246 Ok sweet. Thanks you guys. :)
By asianrob
#203285 i'm pretty sure you can use D16A rods they are far stronger than z6 or y8 rods.
By d16drey
#219725 sure you can use the d16a rods..but change the connecting rod bolts to a aftermarket one..like arp connecting rod bolts..
d16drey wrote:sure you can use the d16a rods..but change the connecting rod bolts to a aftermarket one..like arp connecting rod bolts..
x2 ARP rod bolts ftw!
