By Axix23
#348889
suspendedHatch wrote:Why not getting it running properly instead of cheating the system?
You're not concerned about mileage, power, and longevity? Seems like these forums would be an unlikely place to find someone like that.
While I was on the motor that failed emissions, I was getting 35-38 mpg. Power was decent but it was a JDM d15b so not much power either way. Longevity, motor went to 200k. Finally got rid of it and went with a k series. So I won't be failing emissions anymore. :thumb:
#348908 If a Honda engine dies at 200k, something is really wrong. Abuse or neglect. I have a VX with over 300k, easily passes emissions, 49mpg city and no signs of wearing out. I have an 88 CRX Si, also 300k. Hauls ass for a stock D series. Passing emissions is a breeze. These two cars are the 11th and 12th Hondas that I've owned.
By Axix23
#348980
suspendedHatch wrote:If a Honda engine dies at 200k, something is really wrong. Abuse or neglect. I have a VX with over 300k, easily passes emissions, 49mpg city and no signs of wearing out. I have an 88 CRX Si, also 300k. Hauls ass for a stock D series. Passing emissions is a breeze. These two cars are the 11th and 12th Hondas that I've owned.
35-38 mpg and being fast as hell ftw! K > all. :)
By 95coupe_dx
#349372 hey guys I need a little help also. my car failed smog and I have no idea why. here's the readings
15mph/25mph
CO
14.2/15.1
O2
0.6/0.2
HC
182/67
CO
.76/.19
NO
2477/195
the car has a brand new Catalytic Converter, an o2 sensor which is less than a year old, fresh spark plugs, oil, wires, cap, n rotor.
any help would be appreciated.
By Zander
#352906 Just went for an emissions test. I drive a 1993 Honda Civic with a B16A JDM swap. I passed everything but the idle emissions....
My Idle Emissions:
442 HC (Failed)
.69 CO (Passed)
10.22 CO+CO2 (N/A)
7.4 O2 (N/A)
780 RPM (N/A)
By skipperjon
#353792 Ahoy! I didn't pass smog at 15mph wondering if you could point me in the right direction. I'm in California. I'll keep this as short as possible.
Its a 1992 honda Civic 4 door manual with 230,000 miles on it. It seems to run pretty good and it passed smog just before I left and only has 4,000 miles since it passed smog 5 years before. Apparently the Cat is really rusted and I did run some of the 5 year old fuel in it just before the tune up.
My car sat for 5 years without being run as I was living outside the country. I did a few things before smoging it (oil change, valve cover, air filter) . I emptied the old fuel and added higher octane (thinking it might help?) and ran lucas fuel cleaner. I passed on my 25mph but not on 15mph and passed on all of the C02. Also reading doctor google someone said it could be O2 sensor so I replaced that and went from 1800(NO) ppm to 1463 (NO)ppm.
For my 15mph
HC (PPM) = 144 Max 96
Co (%) = .37 Max .59
NO (PPM) = 1463 Max 859
For my 25mph
HC (ppm) = 52 Max 79
Co (%) = .34 Max .51
NO (PPM) = 360 Max 798
Before speculate or listen to others speculate what do you think about the numbers? Also there was a tiny crack on top of the air filter box that I put a piece of tape over and it passed all visuals.
Thanks so much! I really don't want to take it to a mechanic as the car is likely worth less then what a mechanic would charge to fix.
