- Thu Feb 19, 2009 4:55 pm
#97498
im having a similar problem.
93 Civic DX 1.5: D15B7: 140,000 miles
Im loosing coolant because its "boiling over" in the overflow bottle. I changed my cap, thermostat, and bled the system. Still having the coolant loss from the overflow.
So after reading this post i decided to check for a headgasket issue and did a block test. No combustion gases showed up in the cooling system (chemical stayed blue), oil is the normal color and consistancy, no oil showing in the overflow tank.
I was able to pressure test my cap, it releases at 16lbs like its supposed to. Im kinda out of options here, my last guess would be the water pump? And input would be great!
