- Sun Jan 11, 2015 7:53 pm
#350957
Hi,
got a little (well maybie big) problem. Recently I have noticed that my car acts weird on idle which is pretty low. Whenever I tried to push gas pedal, rpm would drop for a second and then they would rise normally. It's like a lag . I cleaned IACV but still got the problem. Then I changed the injectors to others (same 240cc B2 injectors) but faced another problem When I want to start the engine, I have to hold gas pedal, otherwise it just won't start... When I get engine running, it revs up nicely, but when I let off the pedal, engine dies. All vacuum hoses are fitted good, so I don't think there should be a problem. When I give full throttle, small amount of oil from muffler comes out, and some grey smoke . Where should I look for a problem??? Could it be, that removed coolant hoses of IACV is the problem (because somehow i managed to lose one... ?
My friend says that timing belt slipped... could he be right?
I'm attaching a video to show how my car acted before I changed injectors
https://www.youtube.com/watch?v=t4XZsQa ... e=youtu.be
Also what about that hissing sound that comes from throttle body? Does it sound ok?
Sorry for these noob questions, it's my first car, so I'm trying to learn about it as much as possible.
