- Mon Nov 10, 2014 5:14 am
#349774
So my car has been running fine till last night my battery died and had to get jumped off. When I got home I cut the car off and tried to start it again and it was dead. So today I went and clean off the battery connections and jumped the car off again took it up the road and back turned it off and tried to start it again and it worked just fine. About 7 hours later I had to go pick my girlfriend up from work got it the car and it was acting like the battery was dead and wouldn't turn over I got frustrated and just held the key turned over and it turned over slowly once then again and again and it started speeding up till it finally started. Got to my girlfriends work turned it off and cut it back and it started right up. I went inside and came back out 30 minutes later and did the same slow start as before. I think my battery's going bad but it worked fine till last night out of the blue always been quick to start up like maybe turnover once or twice then she'd fire up and purr like a kitten. Is there any other problems that could be causing this besides the battery?
Or if you have load tester, you can do the same with one other person help.
That would be the first thing to check.
Then..... going to the alternater, check the cables , checking fuses . etc......
Best of luck
Drive it HARD !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
viewtopic.php?t=28277
