- Sat Apr 27, 2013 10:44 pm
#331091
The car ran just fine in December when I bought the car. It had D15b with a DC sport header, catback exhaust, and intake. I decided to turbo it and do a small build in January so i bolted everything up and ran it and the car was super rough. After trying to figure out the problem we put the car back to stock. The only thing we left on the car different was a skunk 2 intake manifold and bigger throttle body. Now we turn the car back on and it idles fine but we give it some gas and it will die at 3000 rpm. There is no way to get it over this point. Is my chipped p28 ecu going bad? I need some help cause I am at a lose. I can post a video in the next couple days in need be. Thanks
- Sun Apr 28, 2013 3:58 am
#331094
Is it throwing a CEL? Stock injectors? Did you get a basemap put on the ecu for the turbo? Sounds like its running in some sort of limp mode.
Also, be sure you don't have the map and iacv connections switched.
