- Sat Jun 09, 2012 6:51 am
#307781
got a check engine light on my eg hatch with d16z6 swap has p28 ecu
I have had this check engine light on since day one and can't figure it out
I pulled the code and got 6 consistent flashes. I looked it up and says my egt or engine temp sensor, I pulled one from another engine i had that i know was good reset the ecu by pulling the fuse check engine light came right back on a few seconds later checked the code and its the same one.
A friend told me I pulled the wrong sensor so I replaced the one on the back side of the thermostat housing this time instead of the one on the front, then I replaced the sensor that goes to the temp gauge for the heck of it.
Still has the same code after multiple resets.
Other symptoms im having is after engine warms up getting idle surge not sure if its related or not, over time I slowly loose coolant from overflow takes bout 2 to 3 weeks of driving to empty it to low, engine temperature never quite reaches half way point on the gauge and i have never once heard the fan cut on. I have also swapped out the relay on the under the hood fuse, checked the fuses. I hard wired a power wire to test the radiator fan and it does work.
This car has been like this since I bought it. It seems to drive fine as far as I can tell. During hot days I can tell it doesn't have the get up to it like on cold mornings but thats any engine for the most part.
I was thinking maybe I should see if I have a stuck open thermostat? I however was not sure if this would cause the ecu to throw a egt code
