- Sat Mar 31, 2012 2:41 pm
#300476
Engine Turning Off Randomly
***Possibly fixed!: Replaced main relay / fuel pump relay with used one from the junk. At the same time I replaced the ignition switch behind ignition lock. Where the key goes into the steering column. Waiting for results. Looking positive so far.***
****It's been months now and the problem has never occurred again. Most likely it was the ignition switch behind the ignition switch. From what I read when the main relay fails the car won't start at all.****
So I bought the car off my buddy who only had it for 6 months and it looks like he bought it from a guy who couldn't solve the problem. I knew of the problem before I bought the car. I figured I can find the issue, I figured wrong. Lol.
Car: 1995 Honda Civic DX 4 Door Automatic. Bone stock, no mods to anything.
Problem: I has happened to me 3 times as I came to a stop. Right when the car is gonna come to a complete stop the engine shuts off. It's not a shutter, then off. The RPMs drop to idle then to 0. It happened again last night, but this time while I was on the freeway. 70 MPH and the engine cuts out. Again, no shutter or anything. Just cuts out. I pull over. Every time it happens, I have to put the car in "park" in order to start it up again. And, it starts right up. It cranks up strong on the first turn. The engine runs strong. No stutter, miss fire, or CEL. My buddy said it has happened to him serval times and sometimes at parking lot idle too. I can't figure it out.
Attempts to Fix: Here's a list of all new parts.
Alternator
Belts all three
O2 sensor
Distributer
Distributer Cap
Distributer Rotor
Spark plugs
Plug wires
Fuel pump
Fuel pump relay
Seafoamed engine, intake manifold, and fuel tank
Battery
Ignitor in distributo
Module in distributor
Things I checked:
- Ignition switch where the key goes in. Turned the car on. Wiggled the key and banged around it. Car stayed on.
- All fuses under the steering wheel and under the hood. Good and fits firmly.
- Wiring under the steering wheel and behind the aftermarket cd player. All wires are stock, un-cut, and un-spliced. Except for the ones required for the CD player, which I checked and are wired correctly and taped off.
- Ground good. Unscrewed and clean all. Metal brush on Dremel to expose metal.
Things I plan to replace and/or check:
Fuel filter
Fuel pressure regulator
Injectors
ECU
That's all I can think of right now. Any ideas as to what the problem might be? If this has happened to you before and you fixed it with one of the parts I just listed, please let me know. At this point I'm willing to swap out the new parts just in case those were faulty out of the box.
Thanks.
Alternator
Belts all three
O2 sensor
Distributer
Distributer Cap
Distributer Rotor
Spark plugs
Plug wires
Fuel pump
Fuel pump relay
Battery
Things I checked:
Fuel filter
Injectors
ECU
Thanks.
1995 Honda Civic DX Sedan
