- Thu Dec 29, 2011 4:31 am
#287445
Ok now im basing this off my knowledge from taking a 1st gen crx si and putting in a 1st gen integra engine into it since most of the civics that year were carbed.....
you would need either a different engine or drivetrain setup with the correct intake manifold injectors and such its probaly going to be easier to also grab the front chassis harness that goes from headlights to firewall across again and back into the firewall to the other side that big main harness which will allow you to use the obd1 ecu etc since obd0 is a whole different ball game but im going to be talking obd1 since its the best route to go in my opinion....so you have engine corrasponding intake manifold with obd1 injectors obd1 engine harness for that engine and obd1 chassis harness for fuel injection the other thing now im not sure if this is true with egs but you will need a gas tank one that will work with a fuel pump setup for fuel injection at least thats how it is on the older carb to fuel injected swaps and with that the fuel pump leveler etc other then that i think that just about covers it its a fair bit of work but if you can get a parts car thatd be your best investment you get all that
sources
civic-eg
redpepper racing
these sites will help and redpepperracing is for the gen crx civic i was talking about which should give you a basic idea of what you willl need
1980 volvo 242
2001 crv
