- Wed Nov 30, 2011 6:07 pm
#283510
Hi hope someone can help me out on this
Engine b18c Civic eg
If i try starting the car it wont start straight away have to try it a good few times to get it started. Once its started it starts with a misfire i cant give it gas when it first starts as it just dies if i do. After a few seconds of leaving it to idle the misfire go's however when setting off in 1st gear it starts to missfire again unless i give it very light gas then its fine. Also if am in 2nd gear onwards below 2000rpm it starts to missfire when full gas is given and cuts out but if light gas is given its fine. Above 2000rpm it is fine weather i give it full gas or light.
I have checked the spark plugs and leads which seem to be fine. These are ngk spark plugs and nology leads
Really hope someone can help me out on this
thanks
thanks
