- Thu Oct 20, 2011 12:59 pm
#278403
I just put my radiator back in, filled up with antifreeze and there doesn't seem to be any coolant flow through the radiator hoses. It was going fine before and I could feel the pressure in the hoses, now I can squeeze them and there is nothing there. What would cause this?
Run the engine with the radiator cap off and when it reaches normal temps, the thermostat will open and the coolant will begin to circulate. Keep topping off the radiator every time it gets low and you'll fill in all the air pockets and be good.
You may need to have someone hold the RPM's as a couple grand to get the temps up faster.
