- Sun Dec 19, 2010 4:51 am
#228726
Whats up guys my idle is kinda funny ever since i adj. The idle speed screw. Now when im in neutral it feel like the idle drop and it shake a lil bit "a lil" Idk if i adj. It way to much. Cause i turned the screw all the way clockwise. And my idle surge stopped eversince i did that. But now it idle funny and when i press the gas pedal i hear a whistle kind of noise comming from the front or the air vent...please insight on this problem of some sort....
- Mon Dec 20, 2010 3:42 am
#228853
You didn't follow the idle adjustment procedure AND you applied the wrong fix for the problem.
- Tue Dec 21, 2010 1:15 am
#228966
witht he car warm ur supposed to unplug the connector to the valve and adjust it to about 450 rpms. then plug it back in and it should be where it's supposed to be... if the idle air valve is in good working order.. if not clean it and re try..
suspendedHatch wrote:You didn't follow the idle adjustment procedure AND you applied the wrong fix for the problem.
Team XXX Racing/WGHonda
