- Mon Jun 28, 2010 1:06 am
#202306
I'm looking at an H22a4, but it has a spun rod bearing. Would exactly would I need to replace, and would it be worth $300 for the complete motor? Can I get away with just replacing the rods and bearings and crank? Thanks
- Mon Jun 28, 2010 1:29 am
#202310
theoretically yes. depends on the damage of course.
spun rod bearing = low oil pressure so the cylinder walls could be scored too if they werent lubricated. but depending on how much heat damage there was it could be just replacing the bearings to a whole new rotating assembly.
are you buying it in person or online? i would bring your 10,12,14,17mm and take a look.
