- Tue May 11, 2010 2:18 am
#192952
ok so i just put back in my basically stock d15 for a little and it ran fine at first. i had tuned it a little on crome and then one day when i step on it and only when i hit100% throttle my wideband will go all the way lean. thinking it was my tune i adjusted the tables and still no luck, so i swapped out the chipped computer for a completely stock ecu. still does same thing. runs fine around town but when i step on it it goes super lean but on decel it does cut the injectors which makes me think the map is working... and btw when i say lean i mean my gauges maxes out at 20 to 1 and with my aftermarket regulator i need 80psi for it to idle at 14.7. having a hard time figuring it out...i back probed my harness at the ecu and got a good ect reading and my map seemed fine at idle
What's your whole setup?
