- Tue Apr 13, 2010 3:42 pm
#187402
D15B manual
when release clutch slowly in 1st gear without any support of gas pedal,the car seems to moving forward a little bit n slowly rite ?
ok my case is here,doing the same as above release cluth slowly in 1st gear,but u can c the fall of rpm in quick n the engine almost die,release the clutch somemore n the engine shut off.
i know this is normal when release clutch n cause the fall of rpm,but in my case tat is reli abnormal,i dono if my word correct to explan this cause of bad english,but i hope u can understand.
is this gearbox problem ? clutch problem ? or idle adjustment problem ?
thanks for help ~
thanks for help ~
JDM EG is my life
