- Fri Mar 19, 2010 7:13 am
#182238
Ok so if you are like me and building a motor for your car and you shit the bed and forget to take the main caps in cuz they are in a box with the rest of the stuff cuz you tore the motor down 2 years ago... Anyways:
Things you will need:
one 5/16th deep 1/4 inch socket
one 1/4 inch extension
bunch of shop towels
1 can Brake clean
1 sheet of FINE emery cloth
1 scotch bright pad cut into 1//4's
1 ice cream pail
2 different length 7/16th inch bolts
1 nut to fit the 7/16th bolts
2 washers
I think thats it. So mine had some rust and random crap so i wanted to clean then...
one looked like this
anyways it looks like sh.... and something has to be done.
Step 1: take the guide sleeves out. take the 5/16th inch deep socket and start hitting it on a down ward motion on the floor or something hard to make the sleeve pop up and out. for one of the mains you will need that 1/4 inch extension DO NOT LOSE THESE * DO NOT PUT IN A VICE* as this will damage the main cap. once removed it should look like the first pic. sorry no pics of this
Step 2: take that sheet of FINE emery cloth, lat it face down as if it was sitting in the motor and draw a figure 8 with the main until it is clean or you are satisfied with how it looks. sorry no pics of this. But it should look like this.
Step 3: take a 1/4 of the scotch bright pad and put it in the ice cream pail and soak it in brake clean.
Step 4: take the scotch bright pad in one hand and push it into the middle of the main cap and rub back and forth with EVEN PRESSURE as to get even removal. sorry no pics of that. but once that is done to your satisfaction it should look something like this.
Step 5: take the guide sleeves and put them back in. Take the 7/16th inch bolt put a washer on it slide it through the hole, put a washer on the other side and tighten slowly, as to not bur the sleeve, because then it may not go back in the block. Repeat on the other side sorry no pics.
Now that will do one main. Repeat steps 1 to 5 to do the other 4 main caps, and if you are as picky as me the will turn out like this..
and there you go. Good luck, have fun and DONT RUSH
p.s) another wrench
1 can Brake clean
1 ice cream pail
2 washers
p.s) another wrench
www.kelownacivics.com
www.vancouvercivics.com
Build Thread >> http://civic-eg.com/viewtopic.php?t=11803
jamminator wrote:my hatch looks wet all the time... kinda like the girls in it.
