- Wed Feb 24, 2010 8:03 pm
#177481
im not turboed but ive done quite alot of research turbos are reliable to those who use them properly and not to those who boost and go....to build a reliable boosted d you need patience, a good tune(which should allow you to pass smog etc ) and reliable parts not some thrown together pos turbo that has 200+k on it and leaky lines etc just because you didnt spend the time and get the right parts.....
a good tune results in
-Reliability
-mpg
-good for the enviroment i guess since your not running too rich or too lean to where your motor blows up
-And much fun lol
And you can use ls rods to cut costs etc
To be honest reliability of a turbo D comes down to 3 main questions
-How much boost and what turbo your using since mentioned on here by another user you can run 2 different turbos at the same psi but the outcome will be different......
-What parts you are using and how much mileage is on your motor if you start fresh itd be better than boosting stock internals with 300+k miles
-And your tune, you can have a horribly fast car but have to rebuild your motor every 200miles because you keep blowing it up since you didnt tune your car right......
with thse questions in mind a good turbo for auto cross and reliability is a t25 garret turbo smaller turbos allow for good low to mid range power that evens out towards the top end (since your looking at only 2nd gear sometimes in autocross a smaller turbo is better for that since it requires less exhaust flow to make boost.....
A good diy thread to look at is Teal's DIY turbo z6
http://civic-eg.com/viewtopic.php?t=11082
i mean of coarse your not going to get amazing gas mileage like 40+ lol but depending on how you drive you can avoid hitting boost and thusly get better gas mileage.....
but yea in considering turboing my car like i said i have done a large amount of research and thinking and more research you can never do too much research......
And here is an example of a reliable set-up if tuned properly......
(Also you have different ways of tuning the ecu some are better than others so yea that you will need to research to figure out whats best for you)
D16z6 base
ARP headstuds
ARP rod bolts
LS integra rods
stock postons(you could go with vitaras depending on how much boost youd like)
T25 turbo
reinforced/knotchd block just in case
Ported and polished head for flow
T25 turbo and a turbo manifold (if running a external wastegate you would want a manifold where the wastegate is in the center for all 4 runners and not on the 1 exhaust runner...there are different style manifolds as well each with their own drawbacks research is key to find out whats right for you)
And a good tune
now i didnt say too much there just some key parts make the whole difference you dont need to really build yours to handle 35lbs of boost....but to be honest my rule of thumb is if i ever build something im going to build it to withstand more than i am looking to get out of it. since if yo do that then you will be more reliable than someone who only built to what they wanted......
1980 volvo 242
2001 crv
