egsedanguy wrote:well if its a stock 92 lx you have a d15. my car is a 93 lx. if your looking to just swap in the stock motor then your not gaining anything. but it will be the cheapest rout. but if you would like to have some more power, with only a lil more out of pocket, but goes in just as easy as the stock motor, get a b18b1 from a 95-98 integra... you will not be mad when its in.. trust me.. plus you will have tons more upgrades for the b18. like we said, go online and buy the full swap. then you will have everything you need. otherwise check that o ring. just pull off the valve cover and you will see 4 rubber rings were the sparkplugs are. run to autozone or what ever you perfer and pick up a set of new ones. should only run you like 5 buck
I am not sure if I have the original stock motor as I purchased this care several years ago. I cannot find the motor number on the motor. Where can I look to find what model motor I have.. All I see is Honda on the top of the motor...
1992 Honda Civic LX
