- Wed Apr 15, 2015 12:17 pm
#353199
well my car has given me problems before about this speed/rmp needles would flutter then drop to 0 and gauge lights would dim and eventually come to a stop and i found out it was my alternator positive. got it hooked back up and worked fine. but Just a few minutes ago i was just driving and came to a stop sign and started coming back up in second and the car completely just dies all lights die everything just just off completely. checked my battery cables they were connected alternator positive was connected tried to jump it off and nothing no lights no crank nothing. please please help me . ill be on here all day so i will see ur comments instantly thankyou..
- Wed Apr 15, 2015 12:26 pm
#353200
Power comes from your battery, so start there and work your way through the power and grounding system.
1- check the fuses first, this takes a minute or two at most (Look at the big box fuses under the hood)
If this fuse is blown find the cause before replacing it something had to short out to blow those high amp fuses.
2- If the fuses are good get your battery down to an auto parts store and have it tested (If it fails replace it)
3- If the battery tests good start at the terminals and work your way back making sure everything checks out for continuity with a voltmeter is the best way.
