By 95LX_just_in
#352983 hvae brand new falken 195/50 tires on my 15x7's and the inside of the front tires are already beginning to wear quickly and im wondering if my destroyed bushings on the lca/s and shitty tie rods are the culprit. and if i should just buy some prothane bushings for $35 or controls dfor $75 any insight is appreciated thanks
By TrailerTrash
#352984 you need a front end alignment. the toe on your car is set too far out.
if you recently had an alignment then either lowered the car or did anything else suspension related, you need it aligned again.
