- Wed Jul 10, 2013 1:28 am
#334057
i own a 94 civic sedan automatic im running a stock D16z6 vtec engine. i recently replaced the radiator about a month ago because it was overheating. the overheating stopped for a while but than it started overheating once again. it cools down when i drive but heats up when im stopped. also i smell antifreeze when im driving and when its parked. I checked my car there are no leaks what so ever. i check my antifreeze level in the radiator and resvoir tank everyday and there good, so im stuck with this question? why is the smell there and why is it overheating? can it be my water pump? thermostat? any suggestions???
- Wed Jul 10, 2013 2:01 am
#334059
when you check the fluid level, they are good as in the same every day or are they lower but still lots of fluid?
as well have you pressure tested the system for leaks you don't see unless its running.
any signs of fluid on the ground under the car or around the block?
