By xjm92x
#297547 So i have some play with my driver side tie rod as in it jiggles around so is it an easy fix or would i need a shop to do it?
By bks84
#297565 fixing a tie rod is easy, but the alignment thats required afterwards must be done by someone who knows what they're doing.
By 1ACarlos
#297582 I would consider changing both as well just so you don't waste an alignment.
By radicom56
#298224 i agree, if one is bad chances are likely the other side is on its way
By dawg316
#298245 when checking for tierod play. alsso make shure its not coming from the inner tierod as well. isolate the play. and then replace the bad part. get it aligned immediately afterwards
By xjm92x
#298274 Ill post a video tomorrow
